Install problem
Newb-lite
Hey
after a laptop crash i was forced to attempt a re-install of my 3g setup.
I downloaded the dash from vodacom site , but the card wont install right(yes i followed the instructions right)
I dailed 155 and was told they would mail me some inf files which will sort me out. This is not happening ... the mails just never arrived ... (tried company and gmail addresses). Anyone know where i can get the inf files i need?
You did a clean install right?
If it was a clean install the .inf files would have installed. There was a known problem when upgrading from an older version that, in some cases, you had to copy some .inf files by hand.
What is the error message you're getting?
Hi
it was a clean install , but the problem remained. A helpfull tech mailed me the inf files , and all is well again.
hey i need those too... also cant get to see the card can someone mail the inf files to me too please....
v3g.... this is the second time this has happened that those blasted inf s arent on the cd... are they sellling off old stock or is their an incompatibility with certain hp models?
The inf files are on the earlier version of the cd's normally version 4.02. there was a file called novatel fixes. If you like PM your email address and I will send you the zipped files..
