What is the difference in using the HDMI cable to co6ect your surround sound or using rca cables? Better quality?My first would be to connect the [hd-pvr]====(hdmi)====[sound]====(hdmi)====[tv] (assuming your sound has hdmi in/outs.)
Your surround sound will 'strip' the audio out from the hdmi signal and forward the picture on to the tv.
If no hdmi on your surround sound, (my tv has audio out) then [hd-pvr]====(hdmi)====[tv]====(optical/coax)====[sound]
^^ I use this setup because i play divx/xvid videos from my tv's usb inputs.
is there a huge sound difference?
Waste of time if you ask me. Even on so-called 5.1 broadcasts, I get nothing but stereo, even with trying the various soundtrack options.
The first option will depend if his receiver supports audio over HDMI (HDMI repeating).My first would be to connect the [hd-pvr]====(hdmi)====[sound]====(hdmi)====[tv] (assuming your sound has hdmi in/outs.)
It must be a setting somewhere on my decoder. It's also connected by HDMI to my sony receiver. Can't say I've ever seen it change to multi channel audio.
What receiver do you have for your surround sound?
Does your Sony receiver support HDMI repeating? If not, that would be the reason why you get stereo. You can work around it by connecting an optical/coax cable to the receiver for audio, and HDMI directly to the TV.
Are you sure?
I am under the impression that no sound will be played.
Okay,
make sure you are on MM1 or MM1 HD.
Select the Original soundtrack (Not Family).
See if surround option is shown when you select the soundtrack option.
