Internet connection sharing help
Airoblast
hi guys i need some inf please.
i have the uncaped unshape and sharing my internet with some other ppl in my block of flats i resently discovered thy downloading torrents and thy making my internet so slow do u guys know of any software i can load on my server 2003 that i can limit band with and block ports. im using microsoft ICS build in at the moment
thank you
Best bet is go goto your friends who you share your internets with. Install a Netlimiter of sorts. and limit each pc to a set limit. example. 4kb per sec down/4kb per sec up
Nothing's stopping them from changing the limit then.
If you want to limit them to browsing only, disable ics and make them go through a proxy and limit that proxy's speed.
http://www.netlimiter.com/
http://www.handcraftedsoftware.org/ -- FreeProxy. not sure if this can limit itself, if not see netlimiter above
