Inverter and Battery Question
GoneWithTheWindows
Johannesburg
Hi All,
I have a question with regards to my inverter and battery setup.
Currently, I have a 1200Watt Mecer Inverter and 2 x 105AH Deep cell batteries.
I am wanting to add a 3rd battery, will I need to go up to a 2400Watt Inverter or doesn't that matter?
Apologies I know next to nothing about these things.
Please ELI5 it for me :)
Thanks in advance!
Is your inverter a 12V or 24V model? Ie, batteries in parallel or series?
Morning. Is it that box on wheels setup ? Anycase, i have the same system. Adding batteries only makes the system last longer when power is off. So you can use the same Inverter.
No need to go up in watts, you can connect up in way you have 300ah in total.
Not sure if it is serial or parallel, cant remember which one now.
If it's in series you'll need 2 new batteries connected in parallel with the existing ones. If it's parallel you can just add one at a time in parallel.
Nah Just custom-built it. Mine is in a big black plastic thing from builders, has space for 2 more batteries
Just add a 3rd battery all in series if it is 12V. Will take a bit longer to charge (think it has 10A charger).
If it is 24V you must connect in parallel and add two batteries at a time.
754496
Is this series or parallel ? Fck yes .... i'm stupid with this.
Also OP you probably have a 1200VA which is 720W.
You are right...
Does that change anything with regards to adding a 3rd battery?
Another dumb question, if I buy the bigger inverter 2400va will it have any impact on run time?
I am guessing not, though.
@RedViking from your review of that inverter -
754518
So confused, does that mean a bigger inverter does mean longer run times.
