GuRu
Killadoob what area you in and how much do you want spend ? and what you want to power
i want to spend a small amount like 1.2k
all i want to power is my adsl router for 4 hours
i think its a 12w router
where from and how much
I blame Tedelex for allowing an unqualified outlet to sell their product.
Someone on this forum said that the changeover to battery resulted in their computer re-booting. This does nor happen to me, except I get disconnected from the internet and have to switch off the modem {router} then switch on again before I can reconnect.
When using a Inverter or Gennie or UPS there is no protection against electrocuting ones self!
Are you sure?
My gennie is still connected to the earth, even though the main switch is turned off at the MB - same goes for my UPS (afaik). So as far as my calculations go, the same danger is still there to be electrocuted with or without the Gennie/UPS being used. Not sure how the inverters are put together though...
I just had my Tedelex Intellipower 4 delivered to my house yesterday - could not believe how heavy it is - impossible to lift on your own!
Otherwise first test with LCD TV and DVD player worked out great! Very impressed with the device so far...
Please be careful when using these devices! The house supply has a Earth Leakage unit that is there for our protection. This is bypassed when we use external supplies.
Just got my Intellipower2 from Catz Digital, Fourways for R4 999. I will be writing my review after a few days of testing.
To Howardb - I checked the battery - it is 100ah.
While there is no load shedding is it better to have my inverter unit switched off or should it be on at all times? I'm thinking of what's best for the battery.
