iPhone 13 Pro & Wireless Issues
Dolby
Probably a handful of times in the past weeks while at home, the iPhone just loses all throughout (although still connected )
Anyone else experiences WiFi issues ?
No, have never experienced anything like that with any of my iPhones I’ve had…
Are you on iOS 16?
Or still on 15?
16 had some issues but mainly if you had changed the DNS servers. No issues in general now though
Do you have this on by any chance?
Only thing I can think of, if this is ON and WiFi signal is not great it can end up switching between WiFi and 4G.
Had that in some areas in the house before I installed a mesh.
Mine is on .
I'm using a mesh right now and haven't had issues before
Mine is on .
Maybe switch it off for a while and see if it makes a difference.
Nothing else I can really think of, not experiencing the same on any of the phones in the house.
Cool - will see over this week
They say it's common
Many iPhone 13, iPhone 13 mini, iPhone 13 Pro and iPhone 13 Pro Max users have reported issues with their wi-fi connection. So, before we proceed further, know that you are not alone in your struggle.
I think I had this issue a few years ago, not 100% how I resolved it - may be "forget" the network or alternatively "Reset Network Settings" might have done it... I think.
I think I had this issue a few years ago, not 100% I resolved it - may be "forget" the network or alternatively "Reset Network Settings" might have done it... I think.
Forget Network is among the list of fixeds - but I'll try this assist first, then forget :)
Make sure you have WMM and UAPSD turned for your wireless network.
Also are you running any funky DNS tools like AdGuard or PiHole?
I think turning off Wifi Assist should help, on my 13 Pro Max I have not had this issue BUT a friend of mines wife had mentioned a similar issue on her 13 Pro Max and I didn’t think of WiFi Assist at all as it’s one of the features I always turn off when setting up a new iPhone.
Will tell her to try this to, thank you @Kola-CT :thumbsup:
Don’t see how WiFi Assist would have anything to do with losing local connectivity.
In fact it should make it better.
