iPhone 13 Pro & Wireless Issues
Try connecting to the 2.4GHz channel while keeping the 5GHz wifi password saved and the phone will switch between the two.
I had a similar problem and when I tried 2.4 the problem disappeared.
I use a mesh with band steering - so single SSID and it pushes to where ever is best
As per default
So I see Private WiFi Address : On and Limit IP Address Tracking : On
Yeah you may try turning it off especially if you've configured anything on your Mesh specific to that device.
