Clayman
I believe Apple Doctor use generic. Anyone know if iStore use genuine Apple batteries though?
Yes they use the OEM batteries manufactured by Apple in China.
Are you looking for an iPhone battery, Spizzy? You could buy good quality OEM batteries before you go back for around the equivalent of R200 (6s price).
Scroll down to OEM, (I’ve been using the firm for years). It’s pretty simple to replace (or just get a repair shop to fit it for you).
https://www.replacebase.co.uk/iphone-batteries/
If you are not an istore customer, make a booking online and they will waive the R200 fee.
Hkcomputers in cape town have an original for R420, but won't work for me unfortunately. Helpful for those living there![]()
Looks like the battery on my iPhone 6 is on its way out - any recommendations where I can get an original replacement battery in Somerset West/Cape Town?
Seems the way to go, the only downside is the turnaround time, looks to be about two weeks.You can book your iPhone in at any iStore and get an original replacement for like R500 or so. I'd highly recommend it.
Apple doctor parts are generic. So decided to phone around and found screenfreeze.co.za, they offer OEM battery replacement with labour for R600, and it's a walk-in replacement. Still looking for cheaper options.
Sadly that's our best-effort turn around time, this is Africa after all.
In Germany it's replaced at the Apple Store in less than 30 minutes. smh.
