Key won't fit into ignition! Help!
soulman
My key does not fit into the ignition of my Opel Astra (2004 model).
I have tried the spare key as well.
It does not go in at all.:(:confused::eek:
Datura
Captain Faptastic
I don't even know where to begin...
Did it used to fit?
If so is there damage to the ignition from perhaps an attemted theft?
Did you just buy the car?
If so, get the key from the old owner they may have given you the wrong key?
Were you out on the piss last night?
Are you out on the piss now?
You sure it's your car?
alisiaoh
Shame you just derailed the poor person's thread.....
@ OP-do you have small kiddies? maybe they stuck something in the ignition....
adamr
try some Q20 spray ... i think something is stuck in there
Musiclover08
Could be the grooves in your key, something in the ignition. if all else fails, you'll prob have to call the support services of the car manufacturer.
