KIC Freezer specs
Speedster
Hatfield
I'm looking for the spec sheet (or at least energy rating) for a KIC KC0175 chest freezer. It's an older model and my Google skills are letting me down. Anyone know where I might find this info?
the rating plate should be on the back .all chest freezers are well rated because of the design .look on the compressor as to what it is and wattage ,further than that its all generically the same .probably be a class A
N = Normal: suitable for use in ambient temperatures of +16°C to +32°C. ST =Subtropical: suitable for use in ambient temperatures of +16°C to +38°C. T = Tropical: suitable for use in ambient temperatures of +16°C to +43°C.
it looks like an (a) rating of 98 ltre capacity .any chest freezer of that size should be more or less the same value .you will battle to get better than that .r134 is an older gas for fridges etc but still a good gas .
Thanks. That helps. It's quite clearly 175l though.
I would say the A is for amps.
0.98 amps
Old KIC I have and it is marked 0.96 amps
When it's running +-135watts using bneta plug for measuring.
0.98 amps
yip you may be right .spoton.never even crossed my mind that .thats why the bigger 220 litre is 1.10 a .damn im thick tonight
can your KIC beat this .1990 .lives outside works 24 hours a day .zero issues .my dad was in senior management for a company that worked for KIC in the eighties .he allways fondly reffered to it as Kak in cartons .but they had a very good product .
I'm not planning on finding out. I like looking after my stuff.
