CVW
Hi all,
I'm posting here to see if other people have the some problem and if so maybe we can combine forces and do things step for step to try and pin point the problem.
Over the past months of Wrath I've been having Lag issues during Boss fights and also gets disconnected
Monday I upgraded to a 4MBit line & got myself a Unshaped adsl acct. Did VOA25, OS2 & EOE25 Thuesdays with a 200ms ping using lowerping and had perfect conditions.
Then last night we did U25 again and as soon as we started a boss fight there graphics/spells etc gets intense my ping jumps to like 3000ms, I cant do much and most of the times I get disconnected.
Thing is I connected without lowerping then and I still got the lag and disconnects with the unshaped account.
This almost seems to happen on random days. For instance, tonight I might go into U25 and continue the raid and have no lag and no problems at all, but then I'll go into Naxx 25 on Friday maybe and I'll have lag problems again.
Its just like that, some days it works, some days its full of *****
1 - So basically, because of that, I can probly say it is NOT my PC (Core 2 duo, HD4850 GB card)
2- It cant be my windows, why would it work one day and the next not.
3 - Same with firewall\spam\antivirus software. I should have the problem permanently if it was the cause
3 - My network card, well I'd also say it should be a permanent problem if it was my nic
4 - My router, Netgear DG834PN (using it wired) - also not the problem because the problem is not every day
That brings me to 2 things
A - Either there is something wrong with my ADSL line/telephone line connection @ my house and some situations cause it to have problems.
or
B - Its a blizzard thing, in which cause most ppl should have the problem...
Right so who else is sitting with this also and what have you done to try and solve it?
or
