Linux VPS help
The_Ogre
Guys I bought a cheap VPS (centos) to learn aboit linux.
I'm logged in as root, but when I try to create a directory I get permission denied. Why is this?
I thought 'root' is god!
Slow down lol. Do I need to add that to the command?
Apologies, mate, I know nothing about linux and I just wanted to learn the basics :D
Edit: was responding to Lion
You can't somma create a directory in the root folder without executing the command as root. Normally that is done using the command sudo. You'll be asked for admin password.
Rather make a directory in your home directory, not the root. You normally don't want to fiddle with anything in there :p
Eg.
Code:
cd ~/                     This takes you to home dir
mkdir epicfolder        This will make a folder called epicfolder
I just create the directory in FTP first and then just point to that directory in SSH so like: cd /var/games/servers/Proxy
something like that.
Thanks, boys!
How do I reset my install because I'm sure I've messed it up royally.
