Steamy Tom
- Jan 23, 2019
didn't you have a post like a month ago about how you couldn't afford license fee's and the car wasn't running for 6 months?
Well you can look at it anyway you see fit however, taking out that battery every 2 days for a top up will drive you crazy, it's bolted down good in a hard to reach area, so taking it out for a charge will never happen. yes i want to top it up every 2 days, because i don't drive far enough for the battery to get a good enough charge to last long.The problem seems to be that you used an external charger on your battery which is not the intended use, and the onus was on you therefore to remove the battery from the car and place it on the charger. This is squarely your cock up not the car or the battery.
Yes had to redo the engine which cost a ludicrous amount, so had nothing left for anything else, started a new job now so taken care of, i fail to see what this has to do with the question.didn't you have a post like a month ago about how you couldn't afford license fee's and the car wasn't running for 6 months?
You would honestly be better off adapting your setup to deal with an acid spill again adequately...Not expensive at the right place. the electronics to convert the current from the alternator is cheap should i do a diy job, but i'd rather buy something complete for a price i know exists if i can only find that site.
Dude. There is a huge problem somewhere between your battery and your alternator if it is going flat in two days. Especially if you drive it every two days, no matter how far.Well you can look at it anyway you see fit however, taking out that battery every 2 days for a top up will drive you crazy, it's bolted down good in a hard to reach area, so taking it out for a charge will never happen. yes i want to top it up every 2 days, because i don't drive far enough for the battery to get a good enough charge to last long.
Sound... and probably a piss poor half arsed install if you cant get to all the components easily...
Just as an aside, battery in the boot.. which car is it because that is decidedly non-standard for most vehicles.
normally more common on "luxury" german cars, im gonna guess its an old bmw
Your car sat for six months. You got a dead cell and need a new battery. It's got ****all to do with the short drive you do every two days. Next time take the battery out to connect it to your battery tender before it dies.Yes had to redo the engine which cost a ludicrous amount, so had nothing left for anything else, stated a new job now so taken care of, i fail to see what this has to do with the question.
Merc or BMW?Just as an aside, battery in the boot.. which car is it because that is decidedly non-standard for most vehicles.
Merc or BMW?
its not going flat in 2 days, alternator is fine, i just like to keep it topped up.Dude. There is a huge problem somewhere between your battery and your alternator if it is going flat in two days. Especially if you drive it every two days, no matter how far.
If it's not going flat then you are creating a problem that didn't exist. Leave the ****ing thing alone.its not going flat in 2 days, alternator is fine, i just like to keep it topped up.
i simply want to charge a battery inside the car
not a dead cell, voltage is 12.65 resting, which is not great but ok, non of this is applicable, i simply want to charge a battery inside the car because its a pain to take out, not bmw or merc.
Seems like it. This guy has created a problem that didn't exist.Wait, so you were charging a battery that hadn't gone dead?????
