Looking for some serious help
Pixiedust100
i have a friend who stupidly bought a slimline case,
its the Antec Minuet 300
(http://www.cluboverclocker.com/reviews/cases/antec/Minuet300/index.htm)
he is now looking for a GFX(PCI-E)but he also games,now the best that i have come up with is the ATI Radeon X1600PRO 16xPCIE 128-bit 256MB DDR3
(http://www.sybaritic.co.za/store/product_info.php?cPath=74_224&products_id=11135)
Anyone know of a better card for gaming for this stupid and horrid case of his.
lol
Your friend should sell this case or use it as a HTPC, I doubt you'll be able to fit anything better than that ATI.
:D
I don't think that any GPU will fit into that case unless it's something like a 8400GS I would sell that case and get a Gigabyte X2 or Asus
As for the X1600Pro it's kind of a waste of money. Are they getting it cause they are on a budget or because nothing els would fit into the case? :)
Then I suggest that they sell the case as it's just too small :(
Simple solution. Turn the Antec Minuet into a barbecue stand and buy a proper case. Then you can buy the 8400GS, 8800GT, 9600GT or do some real gaming and get the 9800GX2.
hey, don't dis the X1600 pro ddr3, I'm running that bad boy still :p
LOL, well, It looks like you ganna have to see that case. just get a cheap case. I mean, It's not like you gonna be looking at it. Then go out and buy a decent GPU. But maybe you guys should wait a bit for the new ATI cards to be released and the nvidia G200 series
