LTE settings
HUAWEI B618, Telkom uncapped
is this the old uncapped for R599/799 with no speed restrictions or the new uncapped for R899 which is capped at 10mbps with a FUP of 150gb?
what speeds do you get when you do a speed test to speedtest.net or to the mybroadband speed test?
all lte packages change towers automatically by default and this is very much true for telkom lte, there are however a few settings for telkom that you can change which will help.
how familiar are you with logging into your router and navigating through it?
I have the new one for R899, I have attached my speed test,
Do not think you can tell a GSM router to switch to a different/ stronger signal.
I believe you configure it and it will connect to the best option available by default.
Give it a different antenna, or test it at different location to see it will indeed connect to best signal.
