Macbook Pro Bottom Case Foot Replacement KIT (DIY)
How about spending R10 on these little rubber stoppers that can be found in any supermarket?
If you do manage to find any of these, please post where you got them. I've got a 13" 2010 Macbook Pro that's lost two front pads and I'd like to replace them.
I've seen similar rubber pads at Mr Price Home. Comes in a few sizes and you just have to peel and stick. Can also be cut to size quite easily. I bought some that were about 20mm in diameter that I used for something in the kitchen. Worked well.
