Magnet Link -> Dropbox -> uTorrent Solution (to work as .torrents did)
Budza
I used Dropbox as a 'load torrents from directory' successfully with .torrent files. From phone, work, wherever, I could send torrents to torrent box at home. Was great :)
Now, with the Magnet Links, I need to send the url / link to uTorrent, but cannot find a way to do so with existing setup. Is there something I'm missing, or will I need to get the WEB UI setup for remote magnet management?
Any suggestions?
It would certainly be the easiest option to use the remote web interface. Otherwise you can RDP into your box and then use the magnet links :p
Problem is, I'm used to doing it from my phone. IE, browse torrent sites, find torrents, download to phone, upload from phone to dropbox, PC picks it up and it's done by the time I get home.
Not keen to frack around with RDP/Remote UI access from my phone :(
I'll keep trawling and post back should I find anything...
Use usenet. Then you can send the NZB's through dropbox.
