So this is what I have been noticing for everyone posting their line stats and the max speeds they are getting.
Looks like Telkom determines that your max speed is when you SNR reaches 6dB.
I did some googling and since Australia is basically the only other country doing ADSL like SA people have been manipulating the SNR value to 3dB or 4dB to have a higher sync rate.
Has anyone tried this? Its not easy and you would need a very specific router to do that. Even if you had the router to try it would would assume that under the best conditions lowest possible dB on SNR would be 3 so between 6dB and 3dB what would the sync rate increase too?
I currently syncing @ 13.2Mbps with a downstream SNR of you guessed it 6dB. Wish I had a router that I could try it out but it not something that is easy to find and not even sure if it would be worth it if you only get like 1Mbps increased sync speed.
