nevadayz
Hi Guys,
So i'm currently on a 4Mb adsl line with telkom, and even to this simple thing took me a fair amount of work due to the fact that my distance from the exchange means i only technically should get 2Mb.
Anyway, my 4Mb line works well, but i see now that on the http://www2.telkom.co.za/checkadsl/check.htm site, my line area now supports up to 10Mb, where previously only used to be 4Mb.
However, if i go into my router, it shows that my max attainable Sync speed is only ~7000kbps.
So, does that mean if i try to upgrade my line, the best i could hope for is 7Mb or could it be that telkom might change my port/etc(don't even know if that would make a difference).
Basically, not sure if i really want to get back into the ring with telkom, and if its really worth it(i do want a 10mb line though).
Any advice would be appreciated.
btw, i miss Charl
btw, i miss Charl
