MDMA and 8ta/Voda settings
carstensdj
Cape Town, South Africa
Hi All,
Please can you help me out here...
I have an 8ta Sim Card with the Go Big Data Promotion on it, and a Vodacom K3565 USB Modem.
When i open MDMA it shows me the signal strength and registers that it's 8ta signal, but i cannot connect as i only have an option for Vodacom to connect to... (due to previously having Vodacom 3G)
PLEASE assist me with being able to setup a connection for my 8ta SIM to work thru MDMA...
Thanks!
The APN for 8.ta is: internet and dial string: *99# should do the trick.
Setup another dial up networking profile if needs be. This varies between Windows version!
Do be aware that the special 8.ta bundles do not work if roaming on a MTN cell.
Thanks for the advice :)
I have actually downloaded the 8ta software from their site, which works with the Huawei modems and so far it has worked well for me.
