MEGA 100WR2 Wireless problem
snail112
Pretoria
Please help my MEGA 100WR2's wireless is not working. AP and wireless is enabled in the router setup, but the light is not lit up on the front of the router.
I performed a reset, loaded everything still no joy. The Basic screen shows N/A at the AP MAC.
Could this be resolved by upgrading the firmware? Or should I get a new router/modem?
I experianced a problem similar to this with one of my clients, just take it straight to telkom store (I assume that you have the do broadband to have that modem), tell them wireless isnt working and they swap it out on the spot, my client got given some crazy full featured billion with 2 voip ports and all sorts of weird gadgets.
@ KinsZA: I don't have it on any Do package. Just got my modem with the self install and a 1 year warranty, which expired at the end of April.
@ ReWeX: I'll give it a try. What do I have to loose?
Ahh, was a great excuse for a swapout for a better unit.
And you dont have anything to lose
What is the easiest way to setup the Wireless Security? I want it WPA with my password, but it says "Error found on page" when I want to give my own password.
Please help or the resistance will be tested against a 10lb hammer or a 9mm pistol, which ever is the closest.
Did you get it on a two year contract with Telkom? My modem also gave problems after the first year or so, and I swopped it out because the staff at the Telkom shop said it is guaranteed for the full 2 year contract period. Go and visit them and try your luck, you have nothing to loose!
They said if I use Telkom as an ISP it is 2 years, or only 1 years if I don't. I think I'll do some DT (Destructive Testing) on my MEGA 100WR2 and get a new modem/router.
