Mobile LTE router - Cell C and Telkom
rodga
Gauteng
Hi all
Im looking to get a mobile lte router mainly for use on Telkom ie 2300Mhz
But would also be using Cell C occasionally, not sure what frequency they use. Google says 1800/2100??
What are my options that will cover both of these situations? Model numbers would be great!
Where can I get the best device only deal?
Cell C LTE band is 2100MHz. In the areas of enabled LTE-A they refarmed band 1800MHz for LTE, but you should target 2100MHz, as your speeds migh be limited (due to limited spectrum or preference for LTE-A).
Any B315s-936 from Telkom or Cell C (no matter). More info http://mybroadband.co.za/vb/showthread.php/777667-HUAWEI-B315s-LTE-router-discussion-thread
If you want portable device, MiFi routers do their job a well, butI don't know exact model numbers.
Huawei model numbers are always messed up, save yourself the headache and go get the Mifi device from Telkom.
Yeah specifically looking for mobile unit
A cell c operator said they use 900mhz for lte-a
