Hi
My monitor on win xp pc goes into power save mode yet it shows windows splash screen. Works fine when I opt for safe mode.
Any settings I need to change? Moment I change screen detail then monitor goes blank.
Dont think so but its a LG Flatron W1934S.
Have tried putting settings on lowest detail. Recall choosing digital output in an on screen menu but cannot access the menu again.
Can only access control panel settings but then as I said it goes into powersave mode when I choose even low detail options.
If you press F8 during boot, you should get access to the boot options menu. Do you see an entry "Enable VGA Mode"? This will allow you to boot into your WinXp installation with only the resolution set to 640x480. Are you using onboard output or a graphics card?
I attach screenshot of settings. Started up now but again in power saving mode. Some bios setting mode? Yet can hear windows sounds despite blank screen.
