MVC5 date problem
lg127
Hi there
I am fairly new at ASP.Net MVC and have a problem i can't seem to figure out.
I have created a web application using VS2015 and C# and the MVC framework. The data base is SQL Server 2014 and I have made use of scaffolding.
I also made use of data annotations to format my date and has apart from other fields 3 date fields which has been annotated as in my model:
[Required(ErrorMessage = "This field is Required!")]
[DataType(DataType.Date)]
in my view I have:
<div class="form-group">
@Html.LabelFor(model => model.DATEREQUIREDBY, htmlAttributes: new { @class = "control-label col-md-2" })
<div class="col-md-10">
@Html.EditorFor(model => model.DATEREQUIREDBY, new { htmlAttributes = new { @class = "form-control" } })
@Html.ValidationMessageFor(model => model.DATEREQUIREDBY, "", new { @class = "text-danger" })
</div>
</div>
I have also set a datepicker with the date formatted as a shortdatestring.
The problem I have is that the date will display correctly in the list of records but when I edit a record in the list (with a date) the date is displayed as mm/dd/yyyy in the form instead of the actual date (21/09/2016) of that record I am trying to edit.
Thanks in advance..
Try something like this:
[DisplayFormat(ApplyFormatInEditMode = true, DataFormatString = "{0:dd/MM/yyyy}")]
public DateTime DATEREQUIREDBY{ get; set; }
*edit*
Scratch that!
Use this:
@Html.TextBoxFor(m => m.EndDate, "{0:dd/MM/yyyy}", new { @class="form-control" })
*edit*
Scratch that!
Use this:
@Html.TextBoxFor(m => m.EndDate, "{0:dd/MM/yyyy}")
Thank you, I will try that when I get home.
Format your date as dd-MMM-yyyy and never worry about SQL Server vs MVC issues again. 23-Sep-2016 is universal and won't break even if you run it on a Russian server (regional settings, yay)
It's a pleasure. I edited it again to include your form-control class. It should work correctly for you then.
Unfortunately it did not work. Same error. The records date field on the EDIT form is displayed as "dd/MM/yyyy" iso "18/09/2016".
No, it is not the formatting that is the problem. The problem is the date field on the EDIT form is displayed as (in your case's example) as dd-MMM-yyyy" iso "18-Sep-2016". The date displays correctly on the INDEX LIST form.
Then fix it?
I thought that's how you wanted to display it. I'm not entirely sure that I understand your problem.
Thanks in advance..
So if it's showing as dd/MM/yyyy now then isn't that what you wanted? Because you were saying that it was showing as mm/dd/yyyy originally.
If not, then what do you actually want to display?
Apologies for the late reply.
I want is to display the ACTUAL date in the record when I edit the record. Eg. I want it to display 19/09/2016 and not dd/MM/yyyy.
When I create a new record then displaying dd/MM/yyyy in the field is ok to show the user the format. But when an existing record with a value in the date filed is edited I want it to display the actual date value. Hope it makes sense .
Hmmm can you paste the code for your model?
Also a screenshot of what you are currently seeing?
Try
Code:
@Html.TextBoxFor(m=>m.DATEREQUIREDBY, "{0:dd/MM/yyyy}", new { @class = "form-control" })
Model:
// <auto-generated>
// This code was generated from a template.
// Manual changes to this file may cause unexpected behavior in your application.
// Manual changes to this file will be overwritten if the code is regenerated.
// </auto-generated>
namespace IRMS.Models
using System;
using System.Collections.Generic;
using System.ComponentModel.DataAnnotations;
public partial class Change
public int CHANGEID { get; set; }
public string TITLE { get; set; }
public string DESCRIPTION { get; set; }
public System.DateTime DATEREQUIREDBY { get; set; }
public int REQUESTEDBY { get; set; }
public int FORDEPARTMENT { get; set; }
public System.DateTime LOGGEDDATE { get; set; }
public int LOGGEDBY { get; set; }
public int TYPE { get; set; }
public int PRIORITY { get; set; }
public int CLASSIFICATION { get; set; }
public int CATEGORY { get; set; }
public int ASSIGNEDGROUP { get; set; }
public Nullable<int> ASSIGNEDPERSON { get; set; }
public Nullable<decimal> ESTIMATEDHOURS { get; set; }
public Nullable<System.DateTime> STARTDATE { get; set; }
public Nullable<System.DateTime> ENDDATE { get; set; }
public Nullable<decimal> ACTUALHOURS { get; set; }
public int STATUS { get; set; }
public int STATUSPERSON { get; set; }
public string STATUSREASON { get; set; }
public virtual CATEGORy CATEGORy1 { get; set; }
public virtual CLASSIFICATION CLASSIFICATION1 { get; set; }
public virtual CUSTOMER CUSTOMER { get; set; }
public virtual DEPARTMENT DEPARTMENT { get; set; }
public virtual GROUPSTAFF GROUPSTAFF { get; set; }
public virtual PRIORITy PRIORITy1 { get; set; }
public virtual Status Status1 { get; set; }
public virtual SUPPORTSTAFF SUPPORTSTAFF { get; set; }
public virtual SUPPORTSTAFF SUPPORTSTAFF1 { get; set; }
public virtual SUPPORTSTAFF SUPPORTSTAFF2 { get; set; }
public virtual TYPE TYPE1 { get; set; }
Code in the EDIT view:
</div>
</div>
@Html.LabelFor(model => model.LOGGEDDATE, htmlAttributes: new { @class = "control-label col-md-2" })
@Html.EditorFor(model => model.LOGGEDDATE, new { htmlAttributes = new { @class = "form-control" } })
@Html.ValidationMessageFor(model => model.LOGGEDDATE, "", new { @class = "text-danger" })
</div>
</div>
Details & Edit Screens:
https://www.dropbox.com/s/uis79alzhwx7dqq/img01.png?dl=0
Hope this is enough info.
OP is this for a campus project or are you just learning?
A campus project but each student had to come up with his own unique project and his choice of programming language.
I chose ASP.NET (MVC) as I did web programming many years ago (pre-ASP.NET) and it is not as easy to learn as I thought it would be!:o
Try
Code:
See my post at 24-09-2016 02:17 PM for a better explanation of my problem. The date formatting is not the issue now, it is the fact that the date on a record I want to edit is not displayed but the string "mm/dd/yyyy" :confused:
You need to pass the Date property from your controller.
In your Edit HTTPGet method in the controller return the model e.g. making sure the property passed is a date
Code:
           var change= await _changeRepo.SelectById(id); //fetch entity from database
           change.DATEREQUIREDBY=DateTime.Now;//hardcode it to test
           return View("~/Views/Change/_Edit.cshtml", change);
cshtml
Code:
     @model IRMS.Models.Change @*on the first line*@
     @Html.TextBoxFor(model=>model.DATEREQUIREDBY, "{0:dd/MM/yyyy}", new { @class = "form-control" })
