Prometheus
Banned
- Mar 19, 2006
The old system however did not have a minimum requirement. I am not sure if you could connect with a zero balance but you could on vlive which makes sense since it is a free service anyway. Only with the new system was the R1 minimum introduced. A positive value instead of an arbitrary minimum value would make more sense and you'll be surprised how far a kid on mxit can still go with only 10c. What caused the headache was the minimum value on the bundle. You can't use it but can't buy a new one either. Surely someone at Vodacom must have foreseen this? Now that is finally fixed although in an undesirable way with all the problems. I'm really not trying to be nasty here but surely you can see from all this that Vodacom have incompetant people working on these things.@Prometheus, what v3g is trying to explain to you, is that the pre-paid data system is based on and has evolved from the pre-paid voice system, and pre-paid voice has always required a minimum balance in order to make a call or send an SMS or MMS etc, so it does make sense that pre-paid data also has a minimum balance requirement in order to successfully connect, it also makes sense that pre-paid data is not exactly the same as pre-paid voice, so the minimum requirements to use pre-paid data will be slightly different to those of pre-paid voice.
I am not too bothered about the R1 minimum requirement itself. The question is why introduce a minimum balance on the bundle when this will cause problems that need a fix which cause even more problems. The logical step would be to not introduce it in the first place or as they say don't try to fix what ain't really broken.Also, v3g has indicated that a fix has been implemented for the problem where one cannot buy another PPDB near the end of an existing non-expired PPDB, the fix that v3g posted about in this thread, is sufficient IMO, and doesn't require reducing the minimum R1.00 pre-paid balance that I suggested earlier in this thread based on my own unclear understanding of how the system actually works which v3g clarified earlier in this thread.
Only problem is that it's not working now at all.We could continue to debate this R1.00 requirement ad infinitum, however the system is not far off from the way you want it to work, IMO the only issues that remain unresolved are the hard-capping when a PPDB is depleted [instead of going into OOBR territory], and the disconnect pre-requisite for system #2 to return credit back to system #1.
I never claimed to be an expert and from what I can see neither are the people working there. First it takes 2 years to implement something as simple as a prepaid data bundle even other people have said that is just ridiculous. Then they introduce system "requirements" that need a fix which cause even worse problems. Something is seriously wrong there with all these problems. Oh and btw, I mentioned once upon a time that Vodacom can roll out their own network but was told that this could not be done. Now both Vodacom and MTN are doing it exactly as suggested.Again, if you're such an expert, come sort it out. But of course you can't. Reality is you've got no clue on a subject on which you're very fond to make profound statements. Invariably they're warped...![]()
What is your background by the way? What did you study or what are your main subjects at school? Obviously not anything technical.
I did not see any explanation that would not allow for the whole balance to used after a disconnect.You obviously did not read my previous posts on how all this works. Or did you not understand it? Thought you're the expert?![]()
I'm sorry but I have to differ. Buying a bundle is very different from buying a car when there are hundreds of models too choose from and almost certainly one to suit your needs. There are only two real alternatives when choosing a bundle, both expire in 30 days. We can all debate this till death but at the end of the day we all know there isn't much choice in the telecoms market and sometimes no choice at all. I used to buy a product that worked satisfactorily, now when I bought it it didn't work anymore.There is absolutely no difference between buying a car or buying a data bundle. You do your research, decide which product you want and, if the pros outweighs the cons, then you buy it.
Vodacom runs constant user surveys. There's a whole department dedicated to this. You really think they'll spend millions developing a product that won't have an ROI?Economics 101, but then you probably not doing economics at school either.
Vodacom built a product. It's your decision if you want to use it. No-one is forcing you to buy it. (Or did someone hold a gun to your head?) I know Vodacom did its best to come up with a product that will have a broad appeal within the constraints of what can be done. And continuously try and adjust it to better suit user requirements.
So it's either use it or don't? Again that is not the definition of a real free market. If we had at least ten cell networks instead of just 3 we might call it that but from what I hear even the UK who has that option is complaining. Can I use my old equipment with the WISPs? What about the money already invested will Vodacom give me a refund for that? If I later decide to switch in this "free market" will I have to buy new proprietary equipment? I guess if it's proprietary I'll have to. Do any of them get their local bandwidth from anywhere other than Telkom or IS and their int from anywhere other than Telkom. I really can't see where the choice is in this market, can anyone else?Hundreds of thousands of people are using it. If you don't like it, don't use. A free market remember?
There are many more than two players, each with multiple products, thousands in total if you include the WISP's. Maybe do some reading on the subject?
Someone from a large overseas firm posted here about bringing true broadband for only R50. This idea was abandoned not because it wasn't practically achievable but because the law protecting the fatcats wouldn't allow it.Or, if there is such a gap in the market, why don't you start your own broadband company? You're already an expert, now go and do it. Just remember to come here and explain every single decision you made and put polls out on how your company should be run and how the products should be structured.
There's been plenty logical answers on this forum. I spend my weekends typing them up. Read them.
14:30 update:
NOT WORKING
