I have been puzzled the last 2 months about intermittent ADSL speed fluctuations and periods of total data communication loss.
Below is my Dlink 2500U stats right after the last period of reduced speed. Typically I get full line speed on a 2mbps capped account, but for this period of about 45min the speed dropped to 30kB/s down and 15kB/s up.
When the speed drop started the SNR on the downstream was at 11dB. As can be seen above it is now at 18dB and the speed is back to normal. I have also plotted the SNR over a couple of weeks and it varies between as low as 10dB and as high as 21dB. Is this acceptable or even normal behaviour? Could this have the drastic impact on the attainable download speed as observed?
Of more concern is the ratio of Super Frame Errors to Super Frames. Just as the speed drop started the ratio was less than 0.1%, but as can be seen the ratio is now approaching 1%. This was only after about 45 minutes. So clearly the ratio for that 45 minute period was a lot higher than 1%. What impact does these errors have on attainable speed and is this acceptable or even normal?
There are also HEC and OCD errors. I have no idea what these are or if it is important. Any thoughts on this?
During this period of slow speed I did do a continues ping to my ADSL modem and did not see any lost packets or high ping times out of the normal.
I have phoned Telkom before and they did a port reset, but this made no difference.
I just need some confirmation on this forum that there is indeed a problem with my line and that the stats observed on my modem is not normal/acceptable. What do I tell Telkom to come and do. I have the feeling that they will say everything is fine.
