Need help deciding components for mid/high range pc
dude#73
I intend trying to find the right combination of components to upgrade to a mid/high range pc.(view signature for my current specs)Bought an ati 2600 xt 512mb,but need help choosing bigger psu.(but thats another thread):
http://mybroadband.co.za/vb/showthread.php?t=115950
besides the psu,Which components should i upgrade first?(I intend changing EVERYTHING)except maybe my mobo
Note that I do NOT have unlimited funds...
you might want to get more ram. Most have are getting more intensive and require more memory for textures and sound. Getting more Ram is nice boost in removing hitches when entering new areas in the game you play
Ya, get another gig of ram.
You plan on replacing everything? Including the 2600XT?
If you want to replace the CPU I'd go for an E8300 or something. Go for a 500W PSU to be on the safe side.
is it worth it going for expensive ram?
well,i can buy a gig of "good" ram for a grand or so,but wont 4 gigs of "normal ram" for the same price be better?eg.(im sure this is cheaper elsewhere)
http://www.take2.co.za/electronics-corsair-xms2-ddr2-800mhz-4gb-kit-2-x-2gb-3121950.html
http://www.take2.co.za/electronics-...nology-ddr2-800mhz-4gb-kit-2x2gb-3424437.html
http://www.take2.co.za/electronics-...logy-ddr2-800mhz-4gb-kit-2-x-2gb-3121951.html
http://www.take2.co.za/electronics-...memory-ddr2-800mhz-4gb-kit-2x2gb-3431888.html
http://www.take2.co.za/electronics-patriot-ep-viper-series-kit-ddr2-800mhz-4gb-kit-3431909.html
http://www.take2.co.za/electronics-...tency-memory-ddr2-800mhz-4gb-kit-3431889.html
http://www.take2.co.za/electronics-kingston-valueram-memory-ddr2-800mhz-4gb-kit-2x2gb-3424686.html
lol sorry for being so retarded,but now you have an idea what im looking at
You'd probably not even notice ;)
Well then:).Thats exactly what I wanted to hear.Someone told me the difference in low latency ram compared to "standard/normal" ram will only be noticed by the boot up time of the pc using it.(Low latency ram is apparently a few {split}seconds)faster when booting up a pc.other than that, I heard the difference is so minute,it cant be differentiated by the naked eye.
was some oke pulling my leg?Or is this true?
Even if it is minutely faster (which is probably possible) it just doesn't justify the additional costs...
http://www.take2.co.za/list.php?type=
4&cat=710&parent=464&grandparent=
288&subsearch=&filter=&country=&alpha=&order=
RealPrice&page=4
(I cant figure out why it wont go through,just copy line by ine as one link,no spaces) check page 3 & 4 (im only looking at 4gb {2x2gb})
there is a difference between the gaming RAM and normal Ram...
First off where you will see the biggest difference with RAMs, is with their speed (800mhz etc)
then the thing with gaming ram is that it OC better, and has lower timing, eg find the info quicker and more efficiently)
But normal Ram is ok, im using 2Gb DDR2 800 CL6 (i wanted CL5 but i got hussled), OCed to 942Mhz, and the differrence from my old DDR2 533 at CL4 was huge, benchmark score increased ALOT, and access times were better...
I ordered 2GB of Chainteck APOGEE DDR2 800 from Prophecy Friday. Wonder if it will OC good. Mabey u should buy some of them Dude#73?
DDR2-800 is just fine :)
Went from 512mb of DDR400 to 2GB's of DDR2-800 and I can say it's a Huuuge jump!
Gamming ram is a waste IMO you just pay more for Heatsinks and fancy Printed grapchics on the chips, if I want boost I will OC my CPU or get a better GPU. No need to spend more on DD2-1066 or DDR3 ram when you will see a 3-5% diffrence ;)
+1
True, they are (usually) faster but the price just isn't justified :)
"Gaming RAM" isnt meant to be heaps faster, its supposed to be made for OCing, hence the heat spreaders. Normal RAM doesnt need heatspreaders as it doesnt get too hot at normal speeds. A proper set of OCing RAM will go way further than a set of normal RAM and you will be able to tighten the timings even further on it than on the normal stuff.
If you are into quantity and not quality and not looking to OC then stick to the normal stuff.
