Need help with coding
Magnum
Hi all.Ive started my studies and one of the subjects is C++(OMG I hate coding.)
Is there any one here that is proficient in c++ and a professional coder?
Some help with layout and and indentations would be very much appreciated.(The right and neat way please).
It took me the whole of Saturday to get Code-blocks working.It tries to compile a C++ program in C.And no help anywhere.Even hit google and forums.
Finished the first 5 chapters on the study material on Sunday.Doing okey.I can actually complete the mini assignments and they are functional.
Thanks all.:)
Enjoy the day.
Not even a single coding Nazi? Eighter you guys are trolling me or there not is not a single C++ programmer on MyBB. Come on guys help a Newb to learn it right the first time.
Thanks.
I've heard that C++ is to C what Brain Damage is to a Brain.
Alan Kay who coined the term "object oriented programming" said that when he coined that term, C++ was not what he had in mind :P
I think you'll find more help on stack overflow.
Coding Standards
Thanks all.:)
Enjoy the day.
Code blocks tutorials
If coding blocks does not come with a source code formatter then there is most likely a plugin to install. I dont think many people will be up to doing your homework for you.
Make sure you have the mingw version. Then everything should be setup for you.
Thank you very much Egenis
I can code. It does work and I can find faults. I want to do it professionally and neatly. I'm serious about my studies. However coding neatly is not part of the assignment. I want to do it that way.
Make sure you have the mingw version. Then everything should setup for you.
I have the mingw one.10.05 . But if you don't know what the extension must be in order for C++ to work then you're stuck. I had to specify the extension (.cpp). The study material did not provide the correct way. Easy fix. Its done and I had that problem on my laptop as well.
Is this for UNISA?
They were still using devc++ when I did COS1511
If you're worried about formatting, try learn some python. You'll be forced to format ;)
Python is a great language for beginners, and a very good language if all you ever want to be is a beginner :P
Assuming you're running Windows, download Visual Studio 2013 Express for Desktop Applications and use it as your c++ IDE. Its free.
VS2013 auto formats your c++ code as you type, so at least the indentations will be consistent.
Woa guys. I'm not learning to become a programmer.I think the COS 1511 stops at arrays (I did Turbo pascal back in the day PII's was scary and we never heard of MMX). I don't know why programming is even in my coarse selection.But its there and I have to finish it. Time is getting non existent. Bugger-up with my registration. If I had enrolled a month earlier it would have been easy.
Thanks for the info. It will help as an guide for programming. But right now I need to do it on my own.
