Need help with iPhone screen recorder
DeonH
Hi and thank you so long.
I want to make a tutorial on how to search for, install and use a specific App. I use the iPhone 8s' microphone. Everything works 100% until I open the App. This specific App uses music a lot. The moment the music starts, the screen recording switches off the microphone and voice is not recorded.
Has someone figured out a workaround on this?
Maybe go under Settings, and scroll down to the specific app - click on the right arrow and see if you can perhaps turn off access to the microphone.
