Need some help in buying a laptop
Mimen
Randpark Ridge
Hi guys, I needs some help over here man. My housemate spilled coffee over my laptop, which is not, needless to say, defunct.
This really came at a bad time as I had an unforeseen expense that is going to take me a few months to recover from.
Please can someone with the time and inclination point me in the right direction.
The thing is, I'm finding this research into a replacement bewildering. Too many models, brands and specs out there. So, below, I can tell you kinda what I had and hope like hell someone can tell me, “go to this store, ask for xxxx laptop and give them your credit card.
Budget R 8000
Was an Asus but any brand will do with the least chance of going in for repairs for its lifetime.
i 5 processor - I think this is a must have, or faster, the i 5 is already to s low for my liking.
HDMI
WiFi
Optical drive
Intel dual core processor
Touch screen – Now this I loved but it looks like a touch screen adds a significant amount to the price and I’ll have to do without it, if necessarily.
I don't know what the processor speed or RAM was, but if it helps, I stream movies from it to my media player and it needs to be fast enough to do that.
Camera for Skype calls.
I don't even know the display size as long it is the “kinda” standard one people normally buy.
I don't know if the above is enough to go by but it’s the best I’ve got.
R8k is an odd price bracket IMO. Try moving up the price then you'll be able to get an dedicated GPU and maybe an i7 if you shop around. If not you'll be better off with a R6k machine value for money wise.
Wait for the Skylake and new Windows 10 laptops to hit our markets soon. Proper 4 cores on the Skylake mobile Core i5.
If you really need to stay in budget, I would say go for :
Product number: N3543I5520041T
Description: Inspiron 3543: 5th Generation Intel Corei5-5200U Processor (3M Cache, up to 2.70 GHz), 15.6-" HD (1366 x 768) Truelife LED-Backlit Display, Intel HD Graphics 5500, 4GB DDR3L(4GBx1), 1TB 5400 rpm Hard Drive, Dell Wireless-N 170x + Bluetooth 4.0, Internal 8x DVD+/-RW, Windows 8.1 Single Language 64bit, 1Yr Collect & Return Warranty
Price:R7865 inc
http://www.pcint.co.za/en/notebooks
If you can afford to go R2000 over budget, go for :
https://www.incredible.co.za/nb-dell-3543-i5-5200u-8-1tb-2gb-gpu-15
Essentially the same laptop but with double the RAM and a mid range Nvidia graphics chip.(If you want beter performance for video streaming and/or gaming).
Good luck
I would offer to sell you my Macbook Pro 13 inch if you are interested in using Mac OS X, but I think BradleyKZN's suggestion is pretty good based on the specs.
Are you interested in a Dell XPS? i7 CPU, 16Gb RAM, 1Tb SSHD, licenced Windows 10, 17" screen (3D graphics - need shutter glasses). Immaculate, no marks or scratches
However, I am in Cape Town
I got my i5 G5080 with 6 gb and intel 5500 for R6499, but seems the special is over, but see if you can find one as I love mine.
Ok guys thanks for you help. All of it info I used. After some hunting around I landed up with:
Acer Aspire E 15 Touch
Touchscreen
Windows 10
Intel core i5
64 Bit
2.7 GHz
NVIDIA GeForce 2GB dedicated RAM (Even though I have no idea what this really means)
8 BB RAM
1 Terrbyte HD
Optical drive
HDMI
I got it for R 78 00. Hopefully, with my limited knowledge and advice on this forum I perceive it to be a good machine at a good deal.
Thanks again
