UHURUnet? What a name!
51% African ownership is apparently the requirement.African telecommunication companies and investors, including SA, will have a 45% stake and international investors 25%, Shongwe said.
What happened to the 51% local ownership to land in SA?
The Nepad special purpose vehicle will be ultimately owned by more than 120 African telecommunications and other companies and will have a stake of about 30% in Baharicom, the owner and operator of the cable.
Lara Kantor, the chairperson of Digital Dzonga which was created to drive the migration, told the committee that she believed the switch off date might have to be changed as the project was “an enormous and complex” one.
Just a comment about this 51% thing, if the 51% is based on a South African BBBEE requirement, then it should surely be 50.1% African ownership...?from the first paragraph there is an unspecified percentage of the 30% which will be African + the 45% mentioned in the second para which presumably takes it over 51%
..not that 51% actually means anything
Yep, just commenting on the amoral-ised origins of this 51% thumb-suck figure invented by Stalin-Mafole, and that it should probably have been 50.1% in keeping with BEE.@ ic: iirc the 51% figure is immortalised in the Draft Guidelines which purport to relate to cable ownership
Any sign of the phrase "Department of Communistications" from the PPCC?things are going downhill very rapidly at the moment - unprecedented scenes in parliament yesterday as the portfolio committee really laid into the DoC
“I really don’t get a sense of urgency anywhere, neither in the ministry nor the department. I can’t see us doing this thing. This is one of the biggest projects in the country,” Vadi said.
Eric Kohlwane (ANC) pointed out that he did not see any feedback for DOC successes in its strategy and asked if it just waited for the Mail & Guardian's director-general annual report card.
“Just answer simply. Are you able to or are you not able to meet your obligations in terms of the Electronic Communications (EC) Act?” Vadi asked.
..have you come across the cables for cronies article yet![]()
