Network Traceability Issue
IceQB
PE
Quick question guys.
We have some files on network here at work. How would i be able to see who accessed these files?
Who? When? Which work networked pc etc...
What OS are we talking about?
If your on Windows you need to have object auditing enabled on the files and will then be able to view the access in the security event logs. This is however switched off by default as it has a bit impact on performance. So I think your probably out of luck.
Yes windows, will have to find out if its off or not.
Thanks gregmcc
