rtayob
Im a complete newbie in this. Dont even know if its possible. Heres my break down.
I have my shop, my house and my brothers house. Want to link them up via Long range Wifi. Below is 2 scenarios.
1. Is my house
2. My brother House
3. The shop
Distance from house to Shop is about 1.5KM. House to House around 300m. Alot of trees in the area.
Scenario A
http://i42.tinypic.com/2elyz5x.jpg
Shop is central point. Both houses connect to the shop. but from point 2 to 3 There is no LOS. Point 1 to 3 there is LOS but i have to about 5 metre higher than roof height which is already 2 floors high.
Scenario B
http://i40.tinypic.com/s45p8o.jpg
My house is central point. Shop and my brothers house connects to me. Point 1 to 3 there is LOS but i have to about 5 metre higher than roof height which is already 2 floors high. Point 1 to 2 there is no LOS as my grandfathers house is blocking it.
I have no idea where to start. i went on the shop roof with binoculars to see if i can see the the house, and thats all i have done. Do you guys think this is possible as the distance is not that much. Is there any way i can link up without LOS. I heard that on 2.4ghz i might get a decent signal with NLOS. I want to run it as a closed single network between the 3 points. Want to be able to access my point of sale server from the house via normal file sharing, stream from the office server to my PS3, etc...
Ive spent hours on different forums and the internet trying to figure. But with my limited experience i get lost
Looking for a cheap workable option.
1. Is my house
2. My brother House
3. The shop
Scenario A
Scenario B
