no small feat for me...
techead
by the mountain
I know most people here have so many characters, but Im still building my main... :o
Last night I got the full savage saronite set! Took me a while to farm 200 ore, but its done! :)
What should the next step be? Just get to 80 and then look for purples?? :confused:
Yo man, yeah get to 80 and start banging out heroics, get your t9 gear and start pugging icc :D
good luck man
Grats Wicked ;)
I'll /w you this evening for ToC5 normal farming!
toc 5 normal people end up crying i heard lol
one time guy farmed tank trinket 47th run got ninjaed by a dps :P
Heh I've seen plenty tanks & healers ninja dps gear too, especially in ToC5 - that place is cursed for not letting people have that one last damn drop they need and have spent 2 months farming for, so all idea of loot etiquette goes right out of the window when it finally drops.
To the OP, grats on getting your set together but I wouldn't bother crafting anything else really. When you hit 80 ToC5 / ICC5 farming for drops, & random HC's for badges to buy the T9 is definately the way to go.
I would only craft to level up the profession. If it is similar to LW, then there should be a couple of items to craft that is an upgrade for the set and needed to level it up. I think they will be all 80 gear though. Aslo along the emblem grinding, I would do some honor grinding, usually WG. Some slots is difficult to get good gear for, like cloaks. The PvP cloaks isn't ideal, but better than what you will get from emblems and likely drops as well. Just note that my chars are all geared up for casters, so melee might be a bit different.
