Hi everyone! I wonder if anyone can provide some insight
I have an Ecco 1kw pure sine UPS Inverter, but I also have a generator and my idea is that the inverter doesn’t have to use battery power when the generator is running as that is a waste.
My generator was producing between 217 and 222 volts (+-) and the inverter was driving me mad kicking in every few seconds when the voltage would drop below 220v (with 4 beeps every time it kicked in and one every time it was happy with the power again). After extensive research I have adjusted the AVR on my generator to give slightly higher voltage, and I thought this would solve the issue but the inverter is running off battery even though there is decent AC power input
(Photo 1)
It did jump to “normal” for about a split second and then went back to battery mode.
Once the power was back we were all back to normal and working (photo 2)
And then tonight (on Eskom power) it started randomly turning off with one beep (not the usual 4 beeps when the power goes out and it changed from AC to battery. In this case the input stays visible and the output falls to 0 and everything that was plugged in turns off. (Not that much, just a printer a screen and a laptop charger at this stage so definitely not close to overload) - And I now see the output voltage has also decreased after all of this and doesn’t seem to be coming back to normal. (photo 3- most recent)
I am not sure if I possibly changed a mode setting somewhere during the course of the evening and that’s why the voltage looks weirdly low now, but I can’t find my hard
copy of the manual and I can’t seem to find it anywhere online so if anyone has a copy please send to me
