Pc help :(
scotty777
...doesn't know
Johannesburg (Northcliff)
ok... so it's seems like i got a harddrive problem... at first, I thought it was a virus... but then I tried to re-install windows... and it says that there's no harddrive detected... what happened was at first... my pc froze... then, on later discovery, when I tried to restart my pc... It would freeze on start up. that means I can't get important data thats currently on the harddrive... but then when i tried to format the dam thing, It just dies... I then noticed that it's getting REALLY REALLY hot over the silicon chips on the drive... so I do think that it's finally given in... so can you guys also just direct me towards the best/cheapest sata hard drive around? I did have a sata 80 gig (that is until it died on me). I got some friends who can help me with getting the data off the harddrive...
Strange indeed, how old is the drive? You can run Seatools if you can at least get the bios to detect it, that'll do a thorough analysis of it ;)
