qu1k_sh0t
This post has been updated. I have done a whole bunch of tests, but this is a nice summary of what I have gone through so far.
I purchased an Asus motherboard and after transferring my components across I started to have random crashes, but only whilst gaming.
Current setup.
Problem: While gaming the pc will just lock up after a random amount of time.
Intel QX9770 with Gigabyte Gpower2 cooler
Asus Striker 2 Formula
1 x 2gig DDRII 800 Transcend memory
Seagate 620 HD
Creative XFi Gamer sound card
Zotac 9800GTX Amp edition
Aerocool 620watt psu
I have run a tonne of tests. The most important ones being Prime95 for a full hour. With all four cores running at 100% the CPU didn't get higher than 60degrees and did not lock up or freeze at all.
I have also run memtest for a full pass twice over with no errors being reported.
I have swapped out my gfx card, both my Asus 9800GTX+ and my Zotac card were causing lock ups after random periods of time. My previous set up ran with the same components without any problem whatsoever.
I think that my northbridge or southbridge may be over heating, as I recently stuck a 40cm desk fan in the side panel and it seems to have stopped the locking up. I played for nearly two full hours without a crash. What software can I use to check my north and southbridge temps?
Current setup.
Seagate 620 HD
