Hi all and thanks for your help.
Win 10 Prof 64-Bit and 1kVA Mecer UPS.
I need to setup my Winpower software to shutdown my PC with power failure.
I connect from the PC with a USB and to the UPS with Serial port. Windows picked the USB as a Prolific USB and made it Com6 and the serial plug I connected to the UPS. Windows pick up the USB as Com6.
But, Winpower, or any other software I have tried, does not see the UPS?
Am I trying to do something impossible or am I doing something wrong or do I need to buy a serial cable. My PC does have a serial port. My previous PC didn't have a serial port and this is why I have the USB-Serial cable.
I will really appreciate anything to connect the USB with the software.
Thanks so long.
Thanks so long.
