Please help, remote software
proximiti99
I need to connect remotely to a server running a surveilance system via the net. Any1 can advise what's the best route to go? I'm thinking Symantec PC anywhere, but looking at freeware apps :confused:
http://www.logmein.com/
easiest to set up and use... and they have a free version as well if you don't need to do File Transfer (you can use pando or something else for the file transfer).
What DVR Card & software are you running on the Server. Usually the DVR supplier has their own Remote Viewer, eg. Samsung, Kocom, GeoVision, Diginet, Intotech all have their own Remote Viewer Software.
Once you get the Software all you need to do is register a Dyndns host name, then setup port forwarding on the router. It's quite easy to setup, I've set it up a few times.
