chloroformaa
- Nov 1, 2023
Hi .I will be buying a portable AC for regular use and a air cooler/fan for loadshedding (via a UPS) ...
1. Upto what btu can I put the portable AC(or say a split wall AC) into the normal wall outlet and above which btu will I have to plug into a dedicated-circuit wall outlet..?..I read somewhere as 24000 btu but somewhere else as 12000 btu , so not sure on this .
2. How do I determine which wall outlet is simple one and which has dedicated circuit..?..is it that dedicated one has no adjacent wall outlet to it or is it that dedicated one has slightly bigger size or any other way to know it .?
3. For the loadshedding use, I am confused between air cooler and fan...air cooler provided more cooling but I can't keep windows open as all dust will come in ..has anyone successfully used air coolers with all windows closed and still got more cooling than a tower fan and more importantly , is it safe to do so..?..
Regards.
Regards.
