Hosehead
As some of you might have read somewhere on these boards, I've lamented that I cannot find an itsy bitsy swimming pool for under R40,000 from any pool company. Ok, sure I can get a fibreglass kit pool for R31,000 but that's without a hole in the ground or any plumbing so the final cost will edge towards the R40,000 mark. Maybe it's a Cape Town Price fixing racket, who knows. Anyway the long and short of it is that I've finally found a builder who can build a 4x3 swimming pool for R30,000 complete and this with a sprayed fiberglass coating.
Not cheap by any stretch of imagination but with Summer around the corner I'm not waiting another 3 years without a pool, sweating like a pig in the afternoon.
Ozone Generators seem like the healthiest solution (as opposed to Salt water or chlorine pools) but the info is scarce. How does this set up work. Must one have a normal chlorine pool first and just add the ozone generator or can one have a salt water pool and just add the ozone generator? When does one cut back on chemicals? It would appear that HTH and the Pool companies ( who depend on the sale of chemicals) feel very threatened by the advent of Ozone technology and one can't get any information from pool shops or swimming pool companies.
Anyone have the buzz?
