km2
Eskom presentation on managing a power system
I did not go in expecting much from an hour long Eskom presentation, but that was actually really interesting. Thanks for posting it.
I would posit that the *paying* customer base may start taking their business elsewhere.
If reliable Electricity isn't for sale, then self generation starts becoming more and more attractive, especially at current rates, and the pricing its heading rapidly towards. Its also going to be a lot more reliable than Eskom.
180k will get the average house with 20kw daily usage offgrid including batteries in todays money.
(Say about 5kw panels on the roof, and 30kw of battery, plus a 3kw backup generator to cater for repeated winter outages past 2 days of no sun, and all inverters etc for a single phase household)
Some Math / Justification on that
20KW daily usage = 830W/hr on average.
5KW panels will generate over 15KW in winter, and well over 30KW in summer daily, so deficit is 5KW/day or zero in summer.
Assuming 5KW / day worst case scenario deficit
You need roughly 3 x (3 days of battery) x 2 (50% discharge) for usage.
- Batteries shouldn't be drained past 50%, so halve the rated value.
- Cater for 3 days of worst case scenario of no sun.
- Add a generator for generation for worst case scenario getting worse, and batteries go below that point of discharge.
With that in mind, deficit is 5KW odd in winter, so 3 x 5 = 15KW for 3 days of discharge (say 3 days of cloudy weather) x 2 (can't discharge lead acid/agm/crystal batteries more than 50%) = roughly 30KW required in batteries.
28.8KW of battery can be had for a little over R1/Whr eg / 20x12v@120Ah= 28800W which can be run in 24V or 48V easily (battery inverters usually run in 24v or 48v sizing)
12v@120Ah Gel Lead Acid is currently R1500 at retail, or less, which = R30,000 for 28.8KW per 5 years usage worse case.
The good news is that battery prices are headed down, not up.
You know, Eskom is being unfairly blamed on this fiasco.I did not go in expecting much from an hour long Eskom presentation, but that was actually really interesting. Thanks for posting it.
There are tens of thousands of highly committed and competent people at Eskom, who do an incredible job with aging plant and infrastructure.
Ironically, their woes stem from SA's 'honeymoon' period - the 5-6 years after 1994 when all new projects were put on ice because Eskom was going to be broken up and sold off.
That is not Eskom's fault. It made the case, but it was not listened to.
It is the fault of our political overlords.
If I were an Eskom board member, I would make damn sure just about every worker, manager, engineer got a huge bonus. These people are performing a miracle holding together a very creaky system - and that creakiness is not of their making.
In the real world, we should be deeply grateful to the thousands of professionals at Eskom who are managing an incredibly difficult situation with great skill.
They deserve medals, in my view.
On the maintenance, they had no other choice. The instruction to run at the red line comes from their political masters. I know for a fact that Eskom management wanted to bring down baseload systems for essential maintenance and refurbishment, and their only shareholder refused.Eskom is very blameworthy. They got rid of competent people and have failed to carry out preventative maintenance.
This is a complex technical problem for them. With the grid so unstable, the very wild swings of PV feed-in can push the grid over the edge. Especially in the two daily peaks, exactly when solar PV drops away to zero.If only they would help fast track feeding back into the grid! Then I'd give the the purple heart![]()
so is this a uniquely African problem?
Fine, but I can't see why the CEO is paid R22m. His salary should be reduced to R4-8m.
More needs to be done with less in order to balance the country's finances, President Jacob Zuma said in written replies to Parliament on Monday.
"We are fighting wasteful expenditure and corruption. We are also freezing budgets of non-essential goods and services, withdrawing funding for posts that have been vacant for some time, and reducing the rate of growth of transfers to public entities, particularly those with cash reserves," he wrote.
I think your battery sizing is a bit optimistic. You need to account for efficiencies of about 85% and also your inverter will use 40-60W/h.
Taking that into account with 20 20x12v@120Ah= 28800W@48V * (0.85) = 24480W / 2 for 50%DOD = 12240W.
Now add the inverter usage itself lets say 50W = 1200W per day x 3 = 12240W - 3600W = 8640W / 3 days = 2880W actual available. So a shortfall of 2120W per day. You need a battery bank that is at least 43% bigger. Let's make it 50% to be safe, so your R30,000 becomes R60,000. ROI starts to get much smaller. That is why net metering is actually so important. Otherwise it might just not we worth it.
Also I'm not sure how much power solar panels produce when it's raining or very cloudy? With the stated battery bank if your solar is not generating much you only have about 120W per hour at your disposal for the 3 rainy days.
Also it's not recommended to have so many parallel batteries, for some reason, they all seem to recommend getting bigger 2V batteries and running the whole lot in series. So you would rather want to get batteries like these.
The 762aH batteries cost about R3000 each and weighs in at 55kg...
So lets just say your solar panels only produce 5KW total per day for those rainy days, I'm totally guessing this figure. And your usage is still 20KW that is a shortfall of 15KW per day that needs to be stored in your battery bank.
So we need a battery bank that will last us 3 days, which is 15KW * 3 = 45KW.
Lets first just work on 1 day of required power of 15kW.
Lets use the 762aH 2V batteries, we will required 24 of these batteries to get to 48V. This will give us one battery bank of 762aH@48V = 48*762 = 36576 * (0.85) = 31089,6W.
This is still at 100% DOD so we need to half that to get to 50% which gives us 15545W per day. Remember the inverter will use about 1200W per day so you only get 14345W.
The costs is then R3000*24 = R72000! Only for one battery bank. Now we want 3 days worth of power so need two more banks in parallel. That gives us 72 batteries required. 72xR3000 = R216,000.
I'm probably very pessimistic with my calculations...
Got one of these from my wife in Aug for my birthday. Awesome!
