Problem connecting with Afrihost account
Vernon
JHB
So I have no problem logging in with my Telkom or Axxess accounts, but Afrihost for me is a no go.
I phoned them up and they've reset my password, but my router keeps on giving me an incorrect username and or password message. I've reset the router a number of times but that hasn't helped.
As I say, I have no problem at all in connecting with my other accounts (at the moment I'm logged in via axxess) so I just can't figure out what the problem is with my Afrihost login details? :confused: I mean I just checked and I've still got around 2 gb's left, so I'm definately not capped or anything like that. They say there's probably a fault with my line, but how can that be when I connect just fine with my other accounts. :confused:
Has anyone else had this type of problem?
I'm assuming that you are using a Telkom purchased router?
Call 0800 375 375 and have your line reset if you have a non-Telkom firmware router try that and you should be able to connect.
