Problem with router password
Jaluman
Huawei WiFi router B618s – 65d
I enter the address 192.168.8.1
On Statistics window asks to enter user name and password I have with me as both “admin” but it responds as “incorrect user name or password”
Please help to get this correct.
Thank you
Thank you
If those are the credentials on the sticker on the router, and they don't work, it means the password has been changed.
Is it your personal device? If so, try and find that piece of paper you scribbled the password on.
Check that your browser doesn't auto fill the incorrect/old password. I had this issue when connecting via my phone once.
It should have a reset button at the bottom to reset everything to defaults and start from scratch.
Did you manage to fixit ?
