Product Number for a HP ML350
duderoo
Earth
Anyone know where the product number for a HP ML350 is on the server casing?
A little tag tied to the front with a piece of string, or under by the serial number, back or front?
If u remove the top cover it is on the front lip on the inside of the chassis.
That is if used with a rack mount kit. Otherwise remove side panel.
Are u talking about a G1
OK that's a G3.
It on the back a little gray sticker with black writing on it i believe.
I checked but nothing is there only a serial number with compaq below it starting with 7Jxxxxxxxxx. What would the product number be like.
One of these if bought with rack mount kit installed.
The xx is just the country code
359212-xx1
359351-xx1
333374-xx1
333372-xx1
