Hi guys
A colleague is looking for the below. I know the specifications are rough to almost non existent, but you will get the general idea.
Any guidance, thoughts/input are welcome.
Please let me know what is possible etc.
@Thor
Thank you!
@Thor
Thank you!
I need to convert Perfex CRM into a SaaS. Perfex is Open Source.
Please bid only if you have prior experience with SaaS and Perfex customization. Please let me know what's possible/not possible.
The following should be included:
1. Single Code-based. Multi-Tenant Databases.
2. Security to isolate files from other Saas Users / Complete isolation for each Saas client. Media folder etc.
3. Customization should allow Perfex CRM auto-update without the SaaS being overwritten. Modular system?
So, the objective in this project is:
1. Convert / turning Perfex CRM into multi owner / multi-tenant / SaaS
2. Create a registration and package selection system for that owner/tenant, with the ability to pay for the package and upgrade and downgrade if need be.
3. Create a super-admin / admin role that can perform CRUD operations
A breakdown of some of these for the saas solution and changes to Perfex are as follows:
Definition:
Super Admin/Saas Owner - The owner that signs up individual Saas Clients for the solution and is the Super Admin of the whole system
Saas Client Admin - The Client of the Saas Solution
General
1. Saas Client Sign-up screen to sign in and select package type and payments
2. Design the sign-up screen - will send the layout
Saas Super Admin
1. Needs abilities to add Saas Clients, disable Saas Clients, change Saas Clients packages, add and remove modules that the Saas Clients have access to, Saas Clients, create a knowledge base for all SAAS Clients, etc.
2. Multiple Payment Gateway Integration.
Look at converting this into a PWA.
Please reply with an estimated cost and time duration.
Thanks.
