Raspberry Pi and Python?
frika6
Good day,
I would like to know if anyone used Python to play around with the Raspberry Pi?
I'm also looking to get started with Python, I think the Pi would be a nice way test my code. Also note that I'm a noob, BE NICE. Any suggestions and tips would be welcome.
Thank you
Python works fine on the Raspberry Pi. What would you like to code?
There are libraries out there for controlling the GPIO port on the Py via python...
I am using Python and Raspberry Pi's (albeit not the two together - yet) to teach my children about computing. I recently bought a kit / book from Pimoroni called "Adventures in Raspberry Pi, which has quite a few projects and specifically uses Python to run some of them.
On the other hand, if you just want to learn Python, why do you specifically want to use a RPi?
Yip, implemented a headless wardriving rig using only a pibrella and python as the control interface, also implemented a 16x2 LCD menu system as a minimal control UI, also using python in the back.
If you are not going to interact with the hardware, and you dont have a pi yet, there are cheaper alternatives to learn python on any system you already have
How was the shipping experience from pimoroni?
No problems whatsoever. Already received three different shipments from them. One shipment had a small part that did not work - I contacted them and they promptly sent me a replacement part but did not advise me they sent it "First Class Mail". When I contacted them a month later to inquire about why I had not received it, they sent me another one! (I now have two of those...).
Where did you purchase this "Adventures of Raspberry Pi".
I want to use the Pi as it is small and low on power consumption.
Nice to know!
I did some research and it looks to me like Python is a good place to start my programming course.
At the end of the day I would like to use a RPi as my end device.
Pimoroni! Missed that part sorry.
The book is freely available online in pdf format - try google before you buy.
Also search for a book from MagPi called "make games with python" - also freely available in pdf.
(I can't be 100% certain, but both books seem to have been placed online with the publishers' permission)
Google to the rescue. Thanks!
