Zarnicate
I have 2 RCT UPS's.
I use ViewPower to disable the alarm however it works fine for the first power outage but any subsequent outages the thing keeps on bleeping anoyingly.
I then have to start ViewPower again and disable it again (after every outage).
Is there any way to permanently disable the annoying beeping.
I opened it up but also couldn't find the stupid speaker to cut the wire.
If anybody has pictures of where the stupid speaker sit please post them or is there some setting combo that will disable the stupid speaker.
