Had an Audi A6 being repaired there... Picture of the damage attached.
Car was ready after a month - which is fine but the work was rejected (due to an airbag light and the wrong panel trim having been used amongst other reasons) and rejected again about 2 weeks later (airbag light and one or two other things I can't recall).
They also changed the front numberplate which we specifically told them not to do as it only had a very minor stone chip as we did not want the front to not match the back numberplate.
On first look after supposed completion, they had replaced it with a metal one and had installed it illegally (double-sided tape rather than rivets). They agreed to mount them correctly for the next time we fetched the car as well as install metal plates at the back... On the second attempt, they had still not mounted it properly and had used two different sized numberplates for front and back. After waiting over an hour, that issue was sorted...
A week after that we took delivery and returned it the next day due to noises (which weren't there before the accident) when braking and pulling off. Turns out that the impact shock damaged one of the engine mountings... The assessor approved the repair and the car was returned to us once the work was completed
