Hi, as the thread title says.
Need a good 120mm FAN CPU cooler, high performance but shouldn't cost more than R500.
I prefer it doesn't include a fan and IF it does, it SHOULD NOT be a non-standard fan. If the fan fails it should be easy to replace!
Lastly, it absolutely CANNOT be a heat sink that relies on a noisy high-RPM fan. If I wanted that I would have stuck to standard cooling.
Socket 1155, should fit on a Asus P8H67-M LX board.
